Hey folks,
I've got a 25'9" Bennington pontoon (no strakes) with a 90hp 4-stroke merc on the back. With the wife and I alone, it will run 21/22, and tends to run close to max rpm. When we put 6 of our friends in it (isnt this what the big toons are for? :joyous: ) we run about 15 mph. Also, when we ski off it, even with 2 adults in, and one adult skier, we see that just a little more power would take the rope slack out of the wide turns. Last, I think the motor may need to be dropped a bit deeper because depending on the chop of the small lake, it cavitates, or maybe ventilates. That's the background, heres the question...
I found a guy that has a long 25" shaft 125hp similar year 2-stroke that wants to trade for my 20" 90hp 4-stroke, because 25" is too long for his 18' ski boat. I'm fairly new to boats, and am wondering if I might hate this decision later.
Will the 5" longer shaft matter? My 20 inch is mounted 1 hole from as deep as it will go. So I assume I can just mount it on a higher hole.
Will I notice a difference in performance since the 2-stroke is about half the weight of the 400# 90hp 4 stroke.
Will a 2-stroke on a pontoon perform better or worse than a 4-stroke from a torque or top-end power perspective?
You think the noise difference would be unbearable?
I'd have to make a significant drive to make this even swap power-up trade, so I am trying to research a little before I commit. I'm grateful for any comments and personal experience shared.
