Re: re-power force to Johnso
No the motor was probably OK, I bought the boat on eBay and the seller rushed me and I took him for his word that it was a good running motor, I got it home and did a compression test and one cylinder had a hole in the piston, so I got another powerhead off eBay and put it on and it sounds and runs great except at wot then it cuts down, I did some adjusting and almost got that solved and decided that when I go out camping I want to enjoy my time not worry about a engine, I'm not very outboard savy and Frank did help allot but with a little more adjustment and the timing done I think the motor will run good, its got right at 129 pounds of compression on all cyl, nice and even and actually puers like a kitten. The problem with the Johnson was the powerpacks, got it home wend and took it out last night. WOW, what a difference.
