I just changed the Lube in my outdrive but now I need to remove it. Can I drain the lube into a clean container and re-use it or should I spend yet more money and buy a couple more jugs?
It won't hurt it to drain it into a clean container and re-use it, just so long as it doesn't get contaminated in the process. My lower end unit oil is so clean when I drain it every year, I save it and use it for my chainsaw chain lubricant. Good Luck!
Depending on what you are planning to do and what drive, you might not have to drain it. If you are not tearing the drive down, and it is an alpha genII (probably others), it has a check-ball that closes when the drive comes off. The reserve bottle will have to be lowered or cleaned out, though.
On my "1" drive I can pull the whole drive (upper and lower) without draining the lube. If the lower is separated from the upper, then the lube needs to be drained.
