Cariboo Milkman
- Aug 17, 2011
- 33
I have had this 69 650 4 cylinder on a 14 foot glass runabout for about two years now, and have yet to get it to run well enough to plane in less than 30 seconds, if at all. I use it at 3700 feet elevation, it has a 15 inch pitch prop, and it starts and idles well. Boat and motor combination weighs approximately 1000 pounds after adjusting for the weight of the trailer and gear.
Here is what I have done/learned so far:
Carbs have been rebuilt by a qualified mechanic. They seem to be synced as they appear to open and close together.
Plugs have been replaced, and they all look the same after one hour running.
Compression with engine cold is 107 on the lowest cylinder and the other three are 114 to 117.
Spark tester indicates good spark on all four cylinders.
The only thing I can think of to do yet, is Clam's link and sync procedure. If that doesn't work it's time to get rid of it.
Any other suggestions?
