ready to install new outdrive question
fmalott
Hi guys snowmobile projects put away now boat projects start again. i bought a new outdrive for my 1983 470 merc. i'm replacing a I-R version with a SE106. My question is when i removed the old out drive and separated the top and bottom end the two surfaces from both ends that are press against each other they were bare metal the new ouitdrive the surfaces are painted, should it be bare metal for better seal or what should i do?
here are the pictures of new outdrive
dubs283
Re: ready to install new outdrive question
the only place the halves seal is the oil passage
there shoud be a quad ring glued into place on the lower half
pressure test the joined halves before filling with lube
fmalott
yes you can see that ring in the one picture but if the halves only seal at the ring what stopping the water from getting in everywhere else
dubs283
nothing
water can be there, its the way it is designed
achris
More fish than mountain goat
Even if the joining surfaces were sealed, water would still be in there, it's the exhaust passage for the engine and carries 'old' cooling water with it. When the engine is shutdown, that area floods... Hence on need for anything other than the quad ring you saw.
Ayuh,... It's water Wet on both sides when runnin' anyways....
For that matter,.. It's wet on both sides sittin' at the dock too....
fmalott
that's why they say to use a marine spline grease for drive shaft got it. well at least i bought the right spline grease thanks guys!
achris
And if the drive-shaft has an 'O' ring groove, DON'T put the 'O' ring on... Toss it in the trash...
Chris.......
fmalott
Chris.......
no it doesn't have the o-ring grove but the new coupling end does look at picture of the new coupling beside the old one the orings don't line up and the coupling end has a oring groove what does this mean
achris
The new one is for the grease-able coupling. Just put the first 2 'O' rings on and fit it all up, you'll be fine...
fmalott
ok good thanks the warm weather is fast approaching well for you it's still there LOL!
