BIGFISHING
- Jun 23, 2008
- 24
Ok this is my last post on this motor, 1960 75hp rude.....it is geting water
in cyl 2 and 4. all the things i have done and it still is the same. I have tried
2 diff heads and gaskets and one with silicone. I have replace both the
exh gaskets and verified steel is ok. The gas is fresh and tank freshly cleaned. Verified it is not to deep in run tank, it will run for about 10 seconds
and then it takes on water and dies. It seems to be to much water for a small crack to let in. Is there any way when i had the lower end off that a
water tube is out of place and causing this concern. What is nex to try before selling it for parts.
