samo_ott
- Jun 18, 2006
- 5,125
I finally have got all the parts, gaskets & O rings together required to rebuild the lower unit on my Johnson 1958 10hp but have a few questions. My local OMC guy said to use the 3M #847 tube of goop around the spagetti seal and the brush on OMC gasket sealer around the prop seal O ring and under the water pump housing. Is this correct and under the water pump housing do I coat both sides of the gasket? Also do I use the goop or sealer anywhere else? Any other tidbits of advice for me? thx...
p.s. I also followed the forum advice and ground down the tip of a 5/16" metal rod to pop out the shifter bushing to get at the O ring and it worked great - thanks!
