Re: real quick rpm question
Mattttt25, thats a good point. The answer gets very long and involved but heres a short version. <br /><br />After the fuel had the lead removed we found that the existing 2 stroke outboard motors actually lived longer when set up at a higher rpm. Lots of in-water and dyno testing was involved. Lots. Its all related to todays fuel and combustion temps.<br /><br />Remember with a 2 stroke theres no valves to hit the pistons, no lifters to float, no push rods to bend, no timing chain/belt and so on. <br /><br />As for your rig, I would -- if I were propping it out -- try the same model prop in a 19. However, the holeshot is going to suffer unless you change the X dimension. 4 strokes have to have that low gear ratio and big diameter prop to get it as good as it is now.<br /><br />I'd guess that whoever rigged your boat was used to rigging that boat with a 225 2 stroke which has a much different gear ratio. And a 17 would be about right. <br /><br />That being said, I might try a large diameter Turbo but they dont have anything, today, in that diameter. Itd be interesting to compare though.<br /><br />If youll post your top speed, with an average load, we'll run the numbers and see where your slip is.
