rear motor mounts
dolphin1
why did mercruiser change their rear motor mounts,what's the difference ? between the old style and the new style
boat127
Re: rear motor mounts
the old ones had the fibre washer spacer and the double wound lock washer (spring) the new ones are the same minus the double lock washer(spring and are now knurled on the bottom of the flywheel housing. hope this helps:)
SSSuper83
It seems to me they changed them over when they went to the R/MR/Alpha drives. I just put a 228 in my 83, and it had about the last year of the Type 1 drive. The difference is in the width of the mounts, for starters. The old style inner transom assembly/flywheel housing mounting points are about 2 inches wider where they bolt together. Also as previously mentioned the double wound lockwasher was eliminated altogether. The 228 I bought had an Alpha (later) set up on it, so I swapped on the flywheel housing from my old 898 onto the 228, using the lockwashers and fiber washers. Bolted together like it was supposed to be there in the first place. Hope this helps, too!
