artificialreef
- Feb 21, 2009
- 504
I am following the manual about reassembeling the 2 halfs of my R drive following my first impeller change. I put the shift shaft in the forward position so it shows at 6:00 o clock when looking down. After borrowing 2 helpers to lower it down i got it together. When i spin the prop shaft forward it clunks going forward. If i move the shift shaft to about the 5:27 o clock position it spins smoothly in forward. Neutral is about 5:25 and reverse is 5:23. It will go to 6:00, just not smooth. Also please see the attachment. Is the shift shaft all the way engaged? it looks a little high, looks like that raised area on the shaft is supposed to be flush with the casing. Do i need to try this again? Thank you for your response.
