Reattach Shoot Thru Hull Transducer
60thjeep
My fish finder, Lowrance X51, has poor signal. When running the trolling motor, the unit barley picks up bottom and sometimes will not. When running the engine it will not pick up bottom. The depth finder's transducer is right next to the fish finder one and that one works(192kHz). Can I pop my shoot thru hull transducer and try to reattach it or do I need a new transducer? It had an extension cable and yesterday I took that off and ran the transducer cable outside of the boat. It worked better, but still had poor signal.
Chris1956
Re: Reattach Shoot Thru Hull Transducer
I would think different frequency transducers would have different characteristics with the same part of the hull. Can you try a different paart of the hull? Is the TD flat on the hull and wet?
