rebuild 90 i6 ????
reeldutch
my brother in law has a early 70s i6 tower of power 90hp.<br />it has one cylinder with bad compression.<br />i just finished rebuilding a evi crosflow V4.<br />i just want some opinions from people who rebuild the i6 early 70s.<br />is it hard to get the bolds out?<br />it was used in fresh water only.<br />are parts still availeble?<br />how much will it cost to do a overhaul?<br />rebore 1 and hone the rest put new rings on and i new piston?<br />gaskets etc etc.<br />the evi v4 115hp costed about 1000 dollars.<br /><br />will it be worth it?<br /><br />thanks for your opinions<br /><br />reeldutch
jimmbo
Re: rebuild 90 i6 ????
inline 6 90hp were made in 1965, 1978 thru 86 or 87. the 1965 model was a 90 cu.in. block, the rest were 99.8 cu.in. blocks. Parts might be harder to get for the 65 model, but should be easy to get the 78 and later parts quite easy.
DHPMARINE
Generally a rebuild of a motor this old..NO!<br /><br />But do it yourself labor..MAYBE.<br /><br />Be well advised no cylinder head on this block.<br />You will instal the connecting rods onto the pistons and rings.Then you'll connect these to the crankshaft.Then you will lower the whole assembly into the crankcase.Don't forget to compress the rings as you do this.Guess you can tell this is not my cup of tea.<br />DHP
ZmOz
Search for clams_canino on ebay. You can get a "new" shortblock from him for about a grand. Use all your old accessories, and you could even get a 115hp or 150hp for the same price, that will bolt right on for you.
emckelvy
Piece of Cake! Fresh water motor should just fall apart. IMHO, a LOT easier to work on than a V4. The hardest thing about the whole rebuild is dropping the crank, you can do it without special tools it just takes some patience and care. I suspend mine from the overhead and gently lower it in place with an engine hoist or comealong and guide the pistons in, one at a time.<br /><br />You can still get all the internal parts for these motors from Mercury and also the aftermarket, with maybe the exception of the crankshaft, which could be found used at any rate. I would hone out all cyl's, check for scoring and other problems, re-ring all cyl's not requiring new pistons and replace any bad pistons as necessary. <br /><br />You would only need to bore O.S. any cylinder that doesn't meet std specs; any others can stay standard and it won't affect balance or operation in any way.<br /><br />Replace the lower crank ball bearing, it's cheap at the auto parts store. Renew all other bearings as necessary upon inspection. Renew the rod bearings as a matter of course on any cyl on which you replace a piston. Renew seals o-rings, and gaskets.<br /><br />The 99.8 CI 90 is a good, torquey motor that doesn't have the top end grunt of the 115's, 140's, etc but is very economical and a great runner.<br /><br />BTW get the ser # off the motor and we can pin down the exact year and other spec's. If this motor turns out to be an older, 90 C.I. model, it may or may not be worth fixing depending on its internal condition and your desire!<br /><br />If you want to tie in with a bunch of other Inline Fanatics, check out this newsgroup which is dedicated to the Feeding and Care of all Towers of Power:<br /><br />news.kraits.org and the newsgroup is: bigweek.mercury-inlines. In Outlook Express use: tools/accounts/add/news and then follow the prompts.<br /><br />You'll be glad you did!<br /><br />HTH and See Ya on the Newsgroup...........ed
reeldutch
thanks for the info you all.<br />i will check the moter out this week for serial numbers. i know it has a distributer so is this the older 1965? i think it is a 78 but not shore.<br />i think i will drop the LU before tearing down this monster.<br /><br />this moter was running two years ago.<br /><br />thanks reeldutch
Clams Canino
The inline 6 can always be overhauled for 1k or less. Make sure to replace all the seals while it's apart and to check the operation of the check-valve bleed hose from the bottom to the top bearing.<br /><br />-W<br /><br /><br />
Originally posted by reeldutch:<br /> thanks for the info you all.<br />i will check the moter out this week for serial numbers. i know it has a distributer so is this the older 1965? i think it is a 78 but not shore.<br />i think i will drop the LU before tearing down this monster.<br /><br />this moter was running two years ago.<br /><br />thanks reeldutch
phatmanmike
rebuild it, rebuild it, rebuild it !!!! keep that beast going for as long as you can
JasonJ
I say rebuild it. Don't listen to the nay sayers, if rebuilt properly it will last decades...
emckelvy
The 90 HP had distributor up to 1979 or so if I recall. The serial # will tell all.<br /><br />What are the color of the stripes on the side, that'll also help to pin the year down.<br /><br />It's a modern motor if it has one coil, and a power pack mounted on the front cowling support. It'll have (3) wires coming out of the distributor that connect to the power pack.<br /><br />The old 900 (90 HP) had points ign, and 2 coils. Hard to mix them up!!<br /><br />Let us know and we can figure out what you've got............ed
