Rebuild Carbs...
gdean7
Well I ordered the carb kits for my 1985 Force 125. It's got 2 carbs, as you all may know. I have the manual, and it seems like it should take me step by step, but I thought i'd send a post to see if any of you all have any suggestions for me as I dig in to this important part of my boat. Anything that can help, please let me know, thanks for everything!
roscoe
Re: Rebuild Carbs...
Keep all the parts separate.<br />Do not mix the parts between the two carbs.<br />Make sure the carbs go back in the same position they are removed from.
eurolarva
The rebuild kit comes with welsh plugs. They are about 1/4 inch metal discs. If you want to do that carb right you will want to remove the old welsh plugs and clean the holes that those plugs covered. Be real careful removing the old ones. The Clymor has pretty good instructions on the rebuild and most kits come with an instruction guide.
gdean7
Great thanks! I've got the Clymer manual, so i'll do a readthrough of it before i begin. Thanks for your ideas and help! Wish me luck!
