FreeBeeTony
- May 15, 2002
- 3,991
I finished the rebuild of my Mercruiser 160. <br />Bored out 0.030 over w/ new pistons, bearings, rings, oil pump, fuel pump, water pump, starter, rebuilt carb, switched to electronic ignition....<br />Started it for the first time today in the boat!<br />Started right up! Had to adjust the valves, (they were too tight) and the timing and it ran great! Got it to idle smooth at 800 RPM in a few minutes.<br />The problem with the timing is as follows: the engine is a '67, no visible signs of any timing marks. I made a mark on the damper and what is left of the timing mark on the block at what I thought was #1 TDC (piston up and both valves closed). When I checked the timing with a light I was way off my mark. I adjusted the timing by ear, found the sweet spot for best rpms at idle. I know my marks must be off but I wonder how well I set the timing by ear? Any advice here?<br />Do you think I am close enough? Seems to run real smooth in the driveway!!! I am very pleased thus far. Now I have to install a new impellar in the outdrive and a new trim pump. Almost ready for the water!
