Re: rebuild of unknown fiberglass boat
novice1,
First, Welcome to Iboats.
If you want to fix your boat correctly you have come to the right place.
The folks here will help you through your project all the way.
My first suggestion would be to do a little homework, Read as many threads as possible to get an idea of what your in for. You can pick up a lot of information by just reading what others have and are currently doing. I would suggest Opp's thread on "hull extension" for one and then lowkee's thread. Like I said there are several others going on right now too.
One of the posters suggested using silicone as a sealant, I would not silicon shrinks, I would use 3M 4200 or 5200 instead.
Anyways good luck on your project.
Bob
