Starting a new thread since I either un-seized it or it never really was 'seized' in the first place!! Here is original thread
http://forums.iboats.com/showthread.php?t=536184
Motor now turns with ease using 6" rachet or pull cord (muffs and fuel tank are 45 miles away), took off water jacket (busted two bolts, found one that had already been busted and rigged up), successfully removed exhaust cover and I'll let the pics tell the story. Looking for feedback. To me, it looks like it could be run as is, but bottom cylinder not 100%. Wanting some feedback on the best course of action....and I'm not opposed to putting it back together and running it as is until the lack of power gets annoying. Would use this basically as a back-up motor for lakes/ponds, etc. and just for fun, not out on the open ocean where a tip top motor is 100% crucial.
Specs. Although the motor hasn't seen a lot of hours, it's seen a lot of miles bouncing around in the back of a pickup.
Plugs. Had R&Red them so many times adding oil to cylinders when we thought it was seized that who knows which is which, but these are the plugs that were in it.
Top and middle right are my bad, top left is previous prick....who covered it up by trying to drill the SS fastener out and then putting a wood screw in there!! I'm nowhere near redneck enough to use a wood screw on a machine!!
So the two center bolts plus this bottom front bolt on the exhaust cover were a bear, but worked them out successfully.
