Rebuilding 1980 johnson 35 Cant split the case?
1reddog1
Rebuilding 1980 johnson 35 How do I split the case. I watched a video of someone hitting the cam shaft and the case opened. No luck for me. Any ideas?
Is the tapered dowel pin out ?-------Is the carburetor and intake manifold off ??-----Is the lower seal housing off ?
Nobody can see what you are doing.----That is why we ask questions.----I have never had an issue getting one of the crankcases apart.----Have done more than one !
jimmbo
crankshaft sorry not a mechanic just looking for help with my diy project. Thanks for your reply
Getting the Name of the Part correct, makes it a lot easier for others to provide any Help/Advice. A Sarcastic response to some of the Best people on this Board, can get you on the Ignore List very quickly
Crosbyman
now that was not so mean...seen a lot worse and it goes both ways. I am certain FR was just being funny.
lets all use our nostrils more :)
F_R
Actually, I meant nothing insulting or funny. I just said in a few words what was said by others----look for some more bolts, like behind the manifold. I was in a hurry, as I had to go to the bank for an identity / money theft purpose. A stressful day.
jimmbo
It was a valid comment, a lot of people don't take the Intake manifolds off of many OMC outboards and haven't found the bolts hidden in there
Picked up a 94 model 9.9 years ago.----Crankcase cover had suffered because the 2 middle main bolts had not been removed.
1reddog1
You guys are all great at this. Thanks for the suggestions. The screw to remove the leaf plate stripped and I could not remove. I did not see any bolts in the service manual, so I thought I could split the case without removing. You all say there are two bolts beyond this plate. Thanks for your help! I am a rookie, my mistake!! All the best to all of you.
1reddog1
The screw is stripped and stuck. I broke off the removal tool in the screw head. Any ideas how to remove?
There you go !!---Just drill the head off.-----Remove the reed plate .----Remove the hidden bolts.----Cover will fall off.
