Rebuilding carbs
Longbow
I have a 1996 40hp Yamaha motor ,oil injected ,3 cylinder,that needs it carbs rebuilt. Is this something that one can do himself or do I need to take it to a dealer<br />Thanks for your help--Longbow
12Footer
Re: Rebuilding carbs
If you've never done it before, I sugest you take it to a good shop. It's not the rebuilding (beleive it or not) thats a pain,but the calibration. Multiple carbs can sometimes be a problem. You might even need a set of vac*** gages (like they have for motorcycle tuning. As a MOF, most bike shops can tune your carbs after the job.<br />But the rebuilding is fairly straight forward. You will need a gallon can of GUNK (tm) carb cleaner, the shop manual, and the rebuild kits for the carbs.<br />The carb cleaner is mean stuff, and it requires you completely remove all rubber and plastic parts and gaskets before "cooking" them. But the stuff is very thurough, leaving nothing but metal behing
<br /><br /><br />------------------<br />I'm no expert, but I DID sleep at a Holiday Inn last night!
12Footer
I just looked at your message again...That enjine has a single carb,don't it?<br />If it does, you should have no need for vac*** gages,and can setup the carb with the book.<br /><br /><br />------------------<br />I'm no expert, but I DID sleep at a Holiday Inn last night!
12Footer
I keep forgetting,this site dont like the werd vac***.... How 'bout VACK KEY YUME.<br /><br /><br />------------------<br />I'm no expert, but I DID sleep at a Holiday Inn last night!
Longbow
Thanks for your help,the motor has multiple<br />carbs,one for each cylinder--Longbow
corm
Hi longbow,<br />GO for it, they are not that hard to do.<br />You would need a manual to get things set right.
