rebuilding / cleaning a 2007 tohatsu 18hp 4 stroke carb ?
danstead
I want to rebuild my carb, doesn't ilde well at low rpm's. I have been using ring valve cleaner and a fuel additive i got from my dealer for the last 2 years but I'm still not happy. I plan to purchase service manual and rebuild kit, what should I purchase to soak / ultrasonic jets / parts with. I hear about a lot of diff. Chemicals.
Fisherman in pa.
TOHATSU GURU
Re: rebuilding / cleaning a 2007 tohatsu 18hp 4 stroke carb ?
Carburetor cleaner that comes in a one gallon pail from any auto parts store. The brand isn't important.
danstead
Thank you for your input.
pvanv
Yep. 4-hour room temperature bath for all non-rubber bits, followed by a liberal blow-out with generic carb spray.
danstead
Mr. Paul,
Do recommend ultrasonic bath for parts or just static bath?
Thx!
pvanv
As long as you use the aggressive 1-gallon pail of carb cleaner, you should be OK without vibration... but it probably wouldn't hurt -- just don't add heat.
