eurolarva
- Jun 24, 2003
- 4,182
1967 Chrysler 45HP mdl45781 Type B Two stage with glass sediment bowl.<br />Bought the rebuild kit and had some problems removing the press fit fuel pump valves. Who ever did it last time used permatex on the gaskets and I broke one. Got a new one coming however I noticed that the gaskets on the valves were broken and after trying to replace them I can see why. I cant seem to get the gasket to fit around the valve without tearing it. Any Ideas? Also the screwed in valve has a brass collar. Will I have a problem if I press fit one of these brass collar valves instead of of using a chrome plated one. Any help would be appreciated<br /><br />Thanks
