rebuilding my boat
tallcanadian
hey everyone. missed being on here. just wanted to let you all know that i started rebuilding my boat. i will keep all of you updated on my progress. i know right now i got the floor out and i have to say that i have never seen so much rot. every square inch of the floor was absolutely soaked with water as was the foam underneath. i knew it looked heavy in the water but never imagined that is was this bad. i'll include the site for my pics as well. thanks for all your help and i'm sure i will be asking for more help..lol. my site is
http://s146.photobucket.com/albums/r277/tallcanadiansboat/?sc=1&addtype=local
tashasdaddy
Re: rebuilding my boat
i've done a few like that.. how's the transom?
Indymike
First order of business...insulate your garage....fire up the stove then get at it. It will be great come summer and you get her floated! Good luck!
tallcanadian
hey tashasdaddy, i haven't gotten that far yet. but i've got some cracking on the top of the transom where under the trim. i'm expecting the worse since i've seen the rest of the boat. hey indymike, nice site. i can use some of you information, thanks. nice build. i'm hoping to have mine done by the time the ice melts which will be around the middle of may here in newfoundland.
i386
It's Deja Vu. Best of luck.
tallcanadian
just a quick update. i got the top half removed and discovered, although it was suspect, a very rotted transom. two pieces of plywood not glassed together. very bad job done on this. i hope it wasn't factory work. lol. check my site for some update pics. thanks to my brother in law bob for all his hard work on this project.s146.photobucket.com/albums/r277/tallcanadiansboat/?sc=1&addtype=local
Usually there are Tattletale Hints as to whether Somebody has Been There before you........
If you're going to use P/T Plywood to go back together with,......
You'll want to get it Bought early,+ allowed to Really Dry before you use Resins on it.......
Good Luck,............
