Re: Rebuilding my Quadrajets on my 4.3
I did my quadrajet this fall using Cliff's book & parts. I am certain you will be thrilled with the results. Just take your time and it will come out right.
If you are into appearance, only soak the air horn for an hour or two so you don't discolor the finish on the secondary flaps and the choke plate.
There's a cadmium gold finish under the spray black of the external linkages. It's not a functional thing but I cleaned off the black from the linkage cause I like things shiny. Then I redid the black carb paint with most of the links off and the remaining ones masked.
When I put it back together it looked great cause of the paint, some new gaskets, the bright finished links and a new white vacuum break. I hope it runs as good as it looks. I really expect that it will. I used the factory jet sizes, cleaned out the idle channels and replaced the idle tubes, did everything by the book.
Oh, here's something to watch for. Before you remove the upper secondary flaps make note of the position of the adjustment screw. There is a picture of the parts in Cliff's book on page 84. The Mercruiser book describes how to set it using a weird gram force scale that shows how many grams of weight it would take to push open the flaps. I did not see any mention of how to set it up in Cliff's book.
He has a nice forum where you can ask questions, I'm going to hit him up for some info in the spring when I put my boat back in service. If he says to just play with it that's fine too, full throttle runs are a lot of fun!
