I bought a 14' Ouchita V-hull from a local scrapyard last month. Included was a 5.5hp Evinrude Fisherman and this little homemade trailer. I paid 250 for the trio, with all of the titles. The boat was pretty rough but it's water-tight now, and the little 'Rude runs great (needed the usual, impeller, points etc.) After inspection I noticed this weird little trailer needed some work before I will be confident towing it. All of the framework and inportant welds look like they are done pretty well. Some of the other work is shoddy.
Plans:
1. Redo the bunks (they are small and hard on the boat, caused a crack in the hull, gonna make them bigger and wider)
2. Grease the rollers, replace and add if needed
3. Replace the axle
4. Paint
5. Tires
6. Winch needs a little work
7. Lights and Wiring
Anyway the other day I went to the scrapyard and got another axle. You can buy them all day for .25 cents a pound. Got an axle (4 lug, 3500lb?) two wheels, one tire, and the U-bolts and hardware for 20 bucks.
The axle I got with the trailer is some sort of wagon axle I think... Has steerable knuckles that were welded and an I-beam shape. Hubs were not sealed at all so it had to go. Any ideas on what it's from?
What I started with:
How did this thing pass inspection? Maybe it wasn't required in the 70's when they put it together. Redneck engineering at its finest. The other side was made of 3/8 all-thread.
After some quick work with the torch it was stripped down.
What I ended up with:
Plans:
3. Replace the axle
4. Paint
5. Tires
