Rebuilding quadrajet. Two different throttle body gaskets in kit?
Rebuilding a used marine Quadrajet and the carb kit has two different throttle body gaskets in it. One has ports between the main and secondaries. Which one do I use?
Carb body # 17059286 and kit # 18-7095.
Grub54891
Re: Rebuilding quadrajet. Two different throttle body gaskets in kit?
The one that matches what came off of it.
cr2k
Also be sure to use the accelerator pump spring that came with the carb not the kit.
I used the one with the ports and the old spring.
Thanks.
