rebuilding sterndrive
lewski
will a gimble bearing from a 140 mercruiser fit a 120 merc?
jerryjerry05
Re: rebuilding sterndrive
Probably.But you need to make sure the part #s cross.You don't want to do all that work and have to do it again.
Need serial#s and year and model etc.Profile? J
Don S
Sounds like you may be thinking about removing a gimbal bearing from one boat, and putting it in another. If that is what you are planning, DON'T. When you remove a bearing with a slide hammer, you damage the bearing.
