I've got a Mercury 3.0L 4cyl Mercury I/O that was stalling when backing down from running fast to a slow idle. Couple of whacks around the float sometimes helped, so I decided to rebuild the carb. (Mercarb)
Did the whole kit, cleaned out everything, replaced the float too. Reistalled everything.
Now, it will only start with the throttle all the way forward, and it takes a few seconds to catch.
Then it can back down to 1500-2000 rpm and hold there, but I can't pull the throttle back anywhere close to neutral.
Something is off that I can't quite get right. If I keep the choke valve all the way open manually, it runs better and I can bring back the rpms a little more.
Any ideas on my next troubleshooting?
I hate that I made the boat worse, and just before the big weekend to boot.
Thanks for any help you have!
Brandon
Brandon
