Rebuilt starter wrong one?
colligefund
My starter slowly began to show weakness. After a intake hose went,(raw water salt), it really puttered out.
I did all the proper checks, and it was the starter.
I removed it and took it to Don's Auto electric to size up.
I installed the rebuilt one and noticed sizeable gaps towards the fly wheel housing.
Turn it over and nothing but spinning action. I bench tested it and it's throwing out.
Perhaps it wasn't a bargin.
Block number is OL379908
It's getting cold in Rhode Island and I have to winterize.
THanks for your help.
wire2
Re: Rebuilt starter wrong one?
What vintage is the engine?
Pre-'86 5.7 used a 12?" flywheel, post '86 used a 14".
The starters will be in a different position, not sure if they're compatible.
colligefund
I'm not sure what year the enigine is, the hull is a 1994 Bayliner and the block number is OL379908. I checked the flywheel and there's no flat spots or serios wear.
After reading more about auto parts on marine engines, I goofed. Should have gone to the source and got the right starter for the enigine.
Anyone have a year for this block and the correct starter?
THanks.
Chilly in New England...
Bt Doctur
What i have
50-863007A1 stagger bolt pattern, Delco PG260G 11 tooth
Hi-Torque
1996 & newer V6,V8
1999& newer 3.0
muc
"Retired" Association of Marine Technicians...
Engine,Drive,Transom was purchased 4/17/01.
Warranty started on 4/17/01 ended on 4/17/02
Drive S/N 0L457423
Transom S/N 0F311754
MSRP on 863007A1 is $208.33
