Reccomend a starting prop
d.r.
I have a 90 hp inline on a alumacraft flat bottom that i have been playing with . Has good top speed but iam having some problem with prop slip on the hole shot . I can't seem to find the spec on the prop and i have had it off a couple of times . What would be a good prop to try that might cure this problem?
Re: Reccomend a starting prop
Ayuh,... Look Harder, there's Got to be some numbers...
And,...
You've provided absolutely No Info to base an answer on...
At the top of this forum are several pinned threads, explaining exactly what Info is needed...
