Reccomended rpm range @ WOT 83 merc 70 hp???
BassAssassin
howdy, i was wondering if anyone knows how i can find out my rpm range for my motor. i tried going on the merc site to find it but no luck. thanks
walleyehed
Re: Reccomended rpm range @ WOT 83 merc 70 hp???
I'm not sure what the book says, but I set mine up for 6200 with just me, and run around 5800 continuous. Yours is the tripple isn't it???
BassAssassin
ya i have the 83 merc 700 70hp. i have heard not to run it over 5500 but nobody knows for sure. i cannot find where to look either.
jimmbo
Your owners manual says 5000 - 5500.
walleyehed
My 83 70 tripple doesn't begin to produce any power below 5500....I replace a 40HP with the 70, and at 5000RPM it would be about the same speed as the 40.<br />Set it up for 5500-nothing less..I've owned this engine since 1990, and 6k has never given a problem.
D
DJ
Guest
I agree on 5500 plus. That engine likes to rev.
BassAssassin
this is why i love this site, so many people out there to help noobs like me. i run it at WOT from point a to point be though. will it be a problem reving that high or should i let off a bit when i plane and hit top speed of *sigh* 31mph? i guess thats pretty good though for this old motor pushin my 18' monarch. what prop and pitch do you run on your 83 merc? i just bought a 10D * 14P michigan hope thats about right. thanks again
walleyehed
I run a 10-1/4X13 on my Basstracker...I can run a 15 pitch but it trolls better with the 13.
BassAssassin
ok well thats good to hear sounds like i am somewhere in the target area then. but when u go from point a to point b do you run wide open or take it off a notch? and how fast do u hit is 30 decent for that motor? thanks
walleyehed
30 is real good....these are very small props.<br />I like to run hard unless water conditions won't let me. I do however, pull back to atleast 5800 on long runs (over 4-5 miles).
