93_lowe_l170
- Mar 17, 2004
- 13
recently had the short block on my 1993 70hp evinrude rebuilt. After letting the motor idle for a total of about 2 hrs with the water phones on it in the drive way, we would run it for a while, then shut it down, run it etc with brand new gas & oil mixed per the engine builders specs. I finally had a chance to get the rest of the boat wet and check it out. The lake is a no wake lake and the boat performed good until it had been driving a round for a while at basically idle with the forward gear engaged. It would then sputter and die. You would have to crank it a couple times and then it would start then maybe die, then if you got on it a little as soon as you got it started, it would run fine for a while then repeat. <br /><br />Upon returning home and hooking it backup to the water phones it took a couple cranks to start then ran good. After checking everything including the plugs my only guess is I was not running it at a high enough rpm to burn off the fuel bein injected there for causing the carbs to load un and choke the engine. Can anyone else offer input?
