txarmydude
- Oct 24, 2010
- 119
I just had a new stator put in my 1986 Mercury 1150, plus all three carbs rebuilt. All three floats turned out to be bad, so they were replaced as well. My mechanic advised me to remove the Autoblend system, so I did that last weekend. I just had a few questions before I get out there on the lake on Saturday.
1. When I mix the gas, it should be 50:1, right? That is 1 pint per six gallons. The outboard mechanic told me that he mixes his at 1 pint per 5 gallons just to have a little extra lubrication. He said it never fouls the plugs. My question is this: does anyone else out there run a little extra oil in their gas for insurance?
2. What is the best way to mix the gas? My boat has a non-removable gas tank. Should I: a) pour the oil in before adding gas; b) pour the gas in and then add the oil; or c) bring a 5 gallon gas can and mix the oil and gas in the can before filling the tank
3. I understand that WOT on this motor is 5000-5800 RPM. However, when I am out on the lake the boat will go all the way to 6200, maybe 6400 RPMs. Should I get a higher pitch prop to bring the RPMs down? It already has a 19 on there. That seems like quite a bit of prop for a 16' bass boat with a 115 hp motor...
4. Should I spend the money for Quicksilver brand TCW3, or is the cheap stuff OK? My Autoblend that has been removed has oil still in it. However, I added the Quicksilver synthetic blend to it when I first got the boat. I would say it has 50% Quicksilver synthetic blend, 50% whatever. Is it ok to reuse?
5. Final question: what type of gas should I use? Around here they have 87, 89 and 91 octane.
Thanks for y'alls help on this one. These might sound like dumb questions, but I DO NOT want to do anything to blow up this motor...
