Recirculation Hoses, 200 hp john
round2it
I have a 2000, 200 HP carbed Johnson. Last weekend, I did the seafoam decarb. In the process, I noticed a hose not connected. The hose was not connected. That's the reason I started gently tugging on it to see if it was connected. And it wasn't. I have the OEM manual and found the pic of the hose routing and it shows the hose as part of the recirculation system . The hose is black with a yellow stripe running the length of the hose. The pic shows a hose running from each cylinder to each carb. It also shows the hose that's disconnected is the one from the bottom of the block going to the in-line check valve and then to the the upper left carb. Well, I'm here to tell you that I cannot find ANYWHERE on the upper left carb for this hose to attach. (viewed when standing in the boat looking at the carbs) I cannot find the inline check valve. I have looked and looked, took a break and looked some more. I have spent a couple hours pouring over the motor trying to find where it goes. I removed the starter for a better view. NOT. No luck there. Motor runs just great at present. Is it possible that the check valve was left off, or the book is wrong? I hope so. Here is the possible problems listed in the manual for a disfunctional recirc system. (The same manual that shows the hose going to the check valve that I cannot find)<br />Erratic or poor idle characteristics<br />Fouled plugs in lower cyl<br />Exessive smoke when accellerated after long idle<br />Idle quality sensitive to trim angle<br /><br />I haven't noticed any of this to date. But probably will now. At present, I plan to leave this hose disconnected. Heck, I can't find where it goes. Would this cause long term problems?
R.Johnson
Re: Recirculation Hoses, 200 hp john
Looking at your engine from the front with the air box off. Facing the engine, look to you left, under the flywheel, and near top most crank case bolt. See if there is a nipple there.
round2it
Will do next week when I can get down to look at it. Thanks.
