Can someone tell me? The recirculation lines run from the small hose barbs located on what I would call the rear of the case, correct? Should I be able to blow or move fluid freely through these lines? Is there a check valve somewhere in the case that only allows the flow to be one direction? I am not sure if I have a blocked line or if this restriction is normal.
