Recomendation needed: Controls
Edko
I want to install a new side mount control on my 91 Seasprite cuddy. Engine is a 91 5.0 merc, alpha 1 gen 2 outdrive.
The current control is a quicksilver (assuming original?) with tilt/trim and a trailer switch with a neutral push button. The push button is cracked and constantly pops out, I really can't figure a way to keep it in and given the age, would just rather replace it altogether.
Thus far I have been pretty adept at putting this girl back together on the engine side and she runs but for some reason I am drawing a big stupid on which control to buy. I understand I need tilt/trim but looking at the iboats store (where I plan to purchase) my crusty eyes can't seem to detect anything with the trailer switch option.
So, anyone here have a recommendation on which control to purchase? Need a reliable unit that won't break the bank (of course). Thanks in advance.
Cadwelder
Re: Recomendation needed: Controls
You may have better luck with this question in the I/O or Mercrusier sections of the forums.
Edko
Probably. Thanks for moving it Mods.
5150abf
You woudl need another Quicksilver control since they are for Mercury, Morse also makes a genaric controlmbox that should work with your engine but I will leave the homework up to you
Edko
Gotcha, thanks. I was kind of hoping some sort of teleflex, Uflex or other side mount would do the job, but I guess I am limited to what I figured I would be.
Appreciate your reply.
Ayuh,... About any of the aftermarket controllers are easily adaptable to yer cables,...
The "Trailer" switch can be wired through a toggle switch, Anywhere ya want it...
Yer not at All limited in Choices...
Edko
I'm going to slap my forehead for not thinking of wiring the trailer button wire to a toggle switch.
There, slapped.
