JGator
- Apr 14, 2012
- 122
I'm interested in installing an additional battery on the Toon for running a bilge pump into a live well for caught fish when sitting idle without the motor running. I would rather the xtra battery not be mounted in the rear where the other battery is located due to the additional weight in the rear. I would also like this battery to be able to be used to start the motor in the event the main battery has failed for some reason. The distance from where I'd like to mount the battery to the switch would be between 10 to 12 feet. This would include the distance from the floor up to each terminal lug on the battery and switch. What is the max run 4 AWG should be? Of course larger cable is possible as I've not bought any.
Also can anyone point me to a vendor (iBoats by chance?) who would make custom length cable with crimped lugs? I've found 96" as the longest with lugs attached.
TIA
Jim
TIA
Jim
