Boat: Baja Islander 204<br />Year: 1991<br />Engine: GM 4.3l V6<br />HP: 230+ (modified)<br />Outdrive: Yamaha <br />Outdrive PN's:V6-DRA 6T5-CR-110094 (lower assembly) INT-PA 6T4-P-131996 (upper assembly)<br />Trim Motor: Yamaha 4 bolt, 4 wire<br /><br />I've been marginally successful in my hunt for a direct replacement for the motor on my power trim system. But, just in case I can't find any direect replacement parts, could someone recomment an entire system that would be powerful enough to trim out the motor that I spec'd above. <br /><br />I don't mind having to do some rewiring of the system, so if I had to do a replacement completely that would be fine. But I just don't know what would be the appropriate device to be able to handle the outdrive correctly.
