Recommend where to get a rebuilt engine
vv1500
Hi can anyone recommend a source for a rebuilt engine. I had a bit of bad luck this week and my OMC (ford) 5.0 Cobra. I knew I was in trouble when I pulled my spark plugs and found one of them to be completely mangled. I had water in my tank and was trying to deal with it when apparently the valve seal in one cylinder broke and in turn broke the valve and piston. The engine is a 1993 OMC ford block 5.0 and my mechanic is recommending a rebuilt engine as opposed to trying to fix it.
Thanks for the help.
Vinny
Haut Medoc
Re: Recommend where to get a rebuilt engine
Yo Vinny.......:)
Welcome to iboats......:)
Rapido marine in the Miami area...
786 663 3278......
Check them out on ebay.......;)
KaGee
Yo Vinny.......:)
786 663 3278......
Ditto... and Raul does not require your old engine back!. :cool:
wca_tim
ditto on rapido marine. I recently ordered a 4.3 chevy from them. Got with older style block (for 88), vortec heads and roller cam / lifters. They were goot to deal with,delivered on time and so far runs great. Good luck
jdtower23
wca,
Check your PM's....thanks
jspringator
Good luck on my 5.8L rebuild from Rapido Marine. Recommended.
5meter
I've bought two SB Chevy's from Autozone with no problems.
You can get a long block with no core charge for under 1200.00.
Just have it set up for a truck application.
