recommended sealant for below water (aluminum boat)
Robbyracks
Hey folks, tow questions:
Need to seal 2 bolts at the transom that are below the water line. What product would you recommend? I've come across the 3M 4200 and 5200 (the latter being permanent I believe?). This is for an aluminum fishing boat that is trailered and used in fresh water only.
Second question is, can I used galvanized bolts/washers for this type of application or other ? ZInc?
Thoughts? Thanks!
Use 4200 UV
Use stainless bolts
