Hello, I am trying to troubleshoot a problem I am having with my Mercruiser 260R no starting when hot - runs fine for 45 minutes and then when in idle it dies and will not start.
I would like to test my compression and spark and was wondering if anyone could recommend their any specific tools they have used. I see a bunch at Napa and Autozone online. But should I look for anything in particular?
I would like to test the spark at each plug and also between the ignition coil and distributor. Anything special I need to look for?
I would like to have a "maximum" value on the compression tester to I can crank the engine by myself and then go see the results. Also need 8 inch extension to get to my sparkplug ports.
Any specific suggestions would be helpful.
Thanks!
Thanks!
