1996 Crestliner 2160 Phantom with a 1996 Evinrude 130 E130TLED motor. The thing blows out very easily. The only other larger boat I've had had an I/O, but as cruising speed(30mph) the thing blows out with the slightest turn of the wheel unless I trim down all of the way and bury the nose in the water. I've only had the boat for a couple of months and want to make sure some things are setup right prior to spending money on a new prop. I've read threads about the cav plate being 1-2 inches below the transom, is this a good starting setup? The prop is an AL 14.25X21. RPM's at WOT are 5400 and top speed is 42mph. Thanks for any help or suggestions you provide.
