bang4dabuck
- May 24, 2009
- 296
Any reason other than a bad part that I can only get a DIODE reading off of one yellow but not the other ? Per CDI I should get a reading with a diode test one way but not the other on both yellows to red. I am using a Micronta digital multi-tester set at diode. I don't have an analog tester but would seem if my tester can read one diode it should pick up the other. I have returned several used and one new rectifier that I got off Ebay because of failing this test. I don't want to waste my time installing if it can't pass the bench test.
thanks
thanks
