bwguardian
- Jul 19, 2016
- 31
I have a 1999 Mercury 115hp in line 4 cylinder 2 stroke. I just finished up a power head rebuild. Because of time lapse I pulled the battery and put a charge on it. Well, when I installed the battery back in the boat I attached the terminals crossed...positive cable to negative post and negative cable to positive post. The starter would only spin and not engage the flywheel to start the engine. I thought it was the starter and after several attempts I figured what I did stupidly. The engine of course was never cranked up obviously.
After realizing this I crossed the cables back correctly and the engine rolled over a couple times and busted off. I am now reading that the rectifier may be toast because of this. However, the tachometer is functioning so I am thinking the rectifier may be good but chances are the diodes are bad. I did notice while it was running on the hose that if I used the trim motor a little, the engine rpm's would come down some and I had to rev it a little to keep it going. This could be something not related but thinking it is. I am going to be testing tomorrow and any input is appreciated!
I do have a 1994 115hp parts motor and can't remember if the rectifier is the same or not...if so may just swap and see.
