seattle scott
- Nov 1, 2011
- 113
Jeeze I get the timing figured out and now I see the rectifier is smoking and hot. I see that CDI makes a replacement that will replace the obsolete Mercury part F404470-1 and I can get it from Sea-Way Marine here in Seattle, but it is $100. The engine still runs lousy, lots of flat spots when opening the throttle and running real rough and there may be a lower unit seal problem.
So two questions, anyone have source for a rectifier for less than $100 and is the rectifier just part of the charging system and has nothiing to do with poor operation of the motor? Meaning if I replace the rectifier I will charge the battery but the motor will still run like crap?
