Re: rectifier???
(1)if one switchbox is defective will the other have no fire either? I asumed that if one was bad I would still get fire to the other side of the engine.(2) also the rectifier fails on the check from--out of the book "connect the black ohmmeter lead to ground and the red lead alternately to terminals A and C the ohmmeter should show no continuity" I'm getting no reading on A and a reading on C, Thanx, and I'll check on that ground,(3) what does it cost to get the switch boxs checked?
