RECTIFIER
MOMO
HOW DO YOU TEST A RECTIFIER TO SEE IF IT IS CHARGING SYSTEM ? THANKS !!!
Barnacle_Bill
Re: RECTIFIER
Connect a volt meter to your battery. Get a reading with the motor off and then another with it running about 2000 rpm. The voltage should increase to 13-14 volts. Or higher if your system is unregulated.
