I was taking apart carbs on my '90 150 and one of the needle valves was frozen so much I had to use a screw driver to pry it free. It looks different from the other two in this motor, it has a red tip. Are these OK to use, not sure why it was stuck so much, this motor ran last last winter, I had it stripped down since then. Everything looks clean, no rust or anything in the port or on the valve, just the red tip.
