Redoing a '79 Vevnture Bass Boat
dillonheath08
Hi everyone,
New member of the boating community. Owned boats before, but never anything that required maintaining or even restoration. Recently sold what I called my "pond hopper" it was a 8ft. fiberglass two-seater boat powered by a 35lb. thrust trolling motor. It was not much but it got me around the smaller lakes with ease and that is really all I needed it for. But the time came when I wanted something bigger, better, greater. After a few weeks or searching on several "For Sale" sites I had yet to find what I was looking for. I was looking for a Plain Jane aluminum Jon Boat that I could put a 10HP motor on and get around some larger lakes. My boat was sold on Friday and that evening my Fiance' calls me and says she may have found me a boat. Her grandfather has a fiberglass boat. I agree to look at it but I tell her I'm not getting my hopes up. We go to look at it and the boat is not as bad as I had expected, it is not perfect but it can be fixed up. The first thing I noticed, the paint, it needed to be redone but it could wait. From there I inspect the trailer. It is in great condition and might possibly need new rollers. No big deal. It does; however, need new tires. Once again no big deal. the carpet inside the boat was redone one year prior to this and seems to be in decent condition. I am not that crazy about the blue. So I will be redoing it. He tells me that the floor is in good condition and has no rotting. I hopped in and the first place I step I nearly go through the floor. This concerns me, but I do not say anything. Finally he begins to tell me about the motor. It is a 115HP Evinrude. It was overhauled last year in May. He took it to a guy and when he picked it up he was able to hear it run and said it ran strong. With a sigh of relief I back my truck up to it and he says "You can have it. Fix it up and use it. Just do not sell it." We shake hands I drive off.
So I am now the proud owner of a 1979 Venture Bass Boat. It is 17ft. long. I have ripped the carpet on the main floor up and the majority of the floor underneath seems to be structurally sound. I will be replacing the entire thing to prevent future hassles. The entire network of wires is there but are currently in a tangled mess under the dashboard/steering wheel. I have straightened them up and began to sort through them. I have redone most every wire in the stern of the boat and connected them to a marine battery. This has gotten me to the point where my 115HP Evinrude will turn over. I am currently working to redo the fuel line (all new hose, inline fuel filter, primer bulb, and engine connection). Once that is done I will see if she fires up, so, fingers crossed! If she does fire up I will be moving on with the floor restoration.
The floor appears to be 1/4" treated plywood with fiberglass on top of that. I am going to be adding 1/2" maybe even 3/4" treated plywood and adding 2 layers of fiberglass on top that followed by some all-weather carpeting.
Any information or links to information on boats like mine or a motor like mine would be greatly appreciated. And also any information fiberglass (resins, cloth, t hardener, mixing rations) would also be a great help.
I am very new to the boat restoration world and have very little knowledge of it!
jbcurt00
I recommend you don't overlay any plywood over the existing deck that's got rotten wood that you can step thru............
You have a fair amount of work ahead, none of it will be easy
GT1000000
Hi and welcome to the iboats.com dry dock, Dillon...
Your pics don't seem to have posted...
No matter, if the deck is rotten, the bad news is that the rest of the substructure is suspect...
The good news is that, no matter how bad it is, you are in the best place to get all the info and encouragement to restore this boat to better than new condition, if that is what you want to do...
I am currently in my 3rd year of restoring my old bass boat and while it might not be the same as yours, a lot of the techniques and construction are similar to what you are about to get into...
Here's hoping the engine is good to go...
Check out the link in my signature and if you decide to go ahead with this, we'll be here to help any way we can...
Good Luck and have Fun!
GT1M:)
dillonheath08
Hi guys. I completely removed the cap of the boat this week. With it out of the way I have begun to cut old wood out and rip out floatation foam. The transom also is coming out one I have cut all of my stringers out and can get to it. Gonna be a long grinding process To remove it I would imagine? I'm hoping that it will come in fairly large chunks that I can piece together to make a template
