Mharrington
- Jul 4, 2020
- 1
Mercruiser engine serial 1A614547
while out at 3900 rpms alarm sounds reading says reduced power. When I go in neutral alarm goes away get back on plane code comes back in about 10 mins.
closed loop cooling
temp is 167
water psi is ok
oil pressure is ok
in the driveway it’s pumping water out at a good rate
im at a lost what’s causing it
closed loop cooling
temp is 167
water psi is ok
oil pressure is ok
