Hello Friends,
I have a 1986 60 HP Johnson outboard. By boat starts fairly easy and idles and runs fairly well at slow to medium speeds. When the throttle is just before about to full throttle it boat bogs down and runs a little erratically like it is about to stall. I am thinking it is a fuel delivery or vacuum issue. I did notice that when I look at the reed valves I see a very small gap under most of the reed valves. I flipped over the reed valves and still see some small gaps. The biggest gaps are only big enough to slide a piece of paper under. How much reed valve gap is acceptable? (Should it be completed sealed or is a small gap ok?)
One other question. Could this effect the vacuum pressure going to the fuel pump? I have to prime the boat every time I start it. When I prime it I see the fuel filter completely filled with fuel. It starts and keeps running but I notice the fuel filter only is about half filled with fuel after running. Most times I have to reprime with the bulb to get it going again.
p.s. when I bought it about 3 years ago I found that they installed a electric fuel pump on it. I changed it out for a regular vacuum driven fuel pump. I'm thinking they put the electric pump on it to compensate for the loss of fuel pressure due to a vacuum leak... possibly at the reed valves.
p.s #2 It has around 140 psi in all 3 cylinders and good spark on all 3 cylinders... and I verified they plugs are firing in the right order.
Thank you!
Thank you!
