outboard geek
- Apr 27, 2005
- 2
1988 110 Evinrude. Given to me recently. Compression is 110 and 110 on the top cylinders. Bottom cylinders are at 75 and 90. Reed valves are bad (open) on both bottom cylinders ( visually inspected). Could this be why the compression is low? Engine was not winterized, carbs were a mess as were the lower reed vlaves, appeared to be water damaged. Any advice would be appreciated. Thanks
